U4GM How to Complete Fire Works Ammo Mod Challenges in Black Ops 7
Posté : 11 déc. 2025, 08:52
Grinding Fireworks camos in Black Ops 7 Zombies can feel rough, and if you go in blind you’ll just waste rounds, so a lot of players jump into a CoD BO7 Bot Lobby or private game and really dial in their setup first. The game only counts kills that come straight from the Fireworks effect itself, not from your gun damage, so if you just spray into the horde you’ll barely see the counter move. You quickly notice that doing 300 of these the “normal” way is painful, because a lot of what looks like a Fireworks kill simply doesn’t register, and the challenge drags on way longer than it should.
Getting Fireworks Ready Before The Match
The first thing you wanna do is stop running the base version of the mod. Head to the research or upgrade station and spend your points on Fireworks right away. The key upgrade to grab is Starburst. Instead of that tiny little pop that tags one zombie and leaves everything else limping around, Starburst gives you an instant explosion that hits the whole group around the target. In practice it means you’re not chipping away at a line of zombies; you’re actually deleting a pack every time the mod procs.
After Starburst, push for the Starlight augment. This one bumps up the number of flares that shoot out when Fireworks triggers, so you’re throwing extra projectiles into the crowd. With no augments you might only see 5 to 10 proper Fireworks kills out of a big train if you’re lucky. Once Starburst and Starlight are online, that number can jump way higher, and you start to feel the challenge bar move every activation instead of every other round.
In-Game Setup And Positioning
When you spawn in, equip your upgraded Fireworks mod and whatever weapon you’re most comfortable landing body shots with, then lock in Aether Shroud as your field upgrade. Do not start firing the second you see zombies. You’re better off finding a wide, safe loop on the map and just training for a bit. Let the round breathe. Once you’ve got a big, ugly ball of zombies behind you, pop Aether Shroud so they stop tracking you and clump even tighter. While they’re stacked and confused, shoot into the center of the group and wait for Fireworks to kick in. When Starburst goes off inside that pack, you can watch a good chunk of the round vanish at once, and most of those will actually count as Fireworks kills.
Boosting Proc Chance And Cutting Down The Grind
If you wanna push this even further, slot in the Citrus Focus augment. It raises the chance of ammo mods triggering, which is huge here because you’re basically living or dying on how often Fireworks actually pops. With Citrus Focus, Starburst, and Starlight all active, each burst can wipe a decent slice of your horde, and your challenge tracker starts jumping instead of creeping. The rhythm ends up pretty simple: build a train, pop Aether Shroud, spray into the middle, let Fireworks clean house, then move to the next pack. Once you’ve got that loop down, those 300 Fireworks kills stop feeling like a wall and turn into a short session you can knock out while you chill or even while you test other setups, and if you want a more relaxed environment to practice this pattern you can always look into a buy CoD BO7 Bot Lobbies option that keeps the pressure low.
